Howling/Grinding/Clunk/Crunch/Squeak/Squeal Noise thread
Old Apr 26, 2013 | 04:43 PM
Tyler Harvey's Avatar
Nice posting Badassbowtie.
Old May 16, 2013 | 01:40 AM
cornwalis's Avatar
If you replace the sway bar link isent the noise its yer swaybar bushings for sure
Old May 16, 2013 | 09:18 AM
front sway bar bushings for sure, and nice post thanks for the grouping of the most common dead horses in the room, they have been beaten and dragged out over the years
Old May 22, 2013 | 10:28 AM
simpkevin's Avatar
simpkevin
Good job badassbowtie
Old Jun 8, 2013 | 03:29 PM
William Robinson's Avatar
how do you replace a fan blade assembly
for a 2007 hhr
Old Jun 8, 2013 | 09:16 PM
Originally Posted by William Robinson
for a 2007 hhr
Start a new thread in an appropriate section of the forum and you will get some useful info.
Old Jun 22, 2013 | 01:56 PM
berni88's Avatar
[Hi. My name is bernadette. I just purchased a used 2009 HHR LS on June 15 from a chevy dealership in PA (delaware county area). I currently hear a crunching noise & another noise (that reminds me of when we would put palying cars in between the spokes of a bike). The car was in the shop on the 17th they thought it was the rotor - they shaved them. I took the car back to the dealership yesterday morning: they thought it was the axel (they took it apart and put a new one it), NOPE that wasnt the cause. The car is still in the shop they will work on it again on monday UGH UGH. (i have a loaner car) HAS anyone ever heard these noises. THANKS
Old Jun 22, 2013 | 10:19 PM
Probably a hub/bearing. I don't know why a Chevy dealer would go through all of that and miss a bearing though, you gotta remove the hub/bearing to remove the axle. Unless you are getting part names muddled up (it happens).
The other things that comes to mind are: water pump, timing chain, chain tensioner/guides. These would be heard engine running, but not in gear.
Oh, just remembered the totally obvious one: flex pipe.
Old Jun 24, 2013 | 07:43 AM
dopplerjeff5000's Avatar
I'm wondering what would be the difference in noise between a bad wheel bearing and bad tires.
I've got a noise consistent with rotation of the wheels but it doesn't necessarily get louder with increasing speed. The 2009 HHR has 60k miles. I bought new tires about 15 months (~20k miles ago), but the tires were really cheap.
The car needed pads and rotors so I replaced them last week. I was kind of hoping the bad rotors were the source of the noise.
Old Jun 25, 2013 | 04:10 PM
Jack the front end up push/pull at 12:00 and 6:00. If you can feel ANY motion it is bearings (this works best when the pads are out, or the calipers are rotated up). Sometimes you can get the wheel to turn if you put the trans in neutral with both wheels off the ground, and fell/hear. Don't forget to check the rear bearings, basically the same.
