Howling/Grinding/Clunk/Crunch/Squeak/Squeal Noise thread
Old Dec 30, 2023 | 01:39 PM
  #61
PulpFriction's Avatar
Check the sway bar links first, then the sway bar bushings.
Old Dec 30, 2023 | 01:52 PM
  #62
Have no idea what #6 is referring to...
Old Dec 30, 2023 | 03:59 PM
  #63
Perhaps the sub frame bushings at the rear axle. Or the thin rubber were the engine cradle bolts up to the rad cradle
Old Dec 30, 2023 | 07:17 PM
  #64
. PulpFriction- Thank You Sir, will do. Fixing to get a warm up in a few days. Then I'll dig into the inspection. Naturally this happens when we are getting cold
RJ- unsure, but all will be checked.
Blue- definitely in Left front. So time will tell.
Thanks All for the replies.
Old Jan 2, 2024 | 09:35 PM
  #65
After only time for quick inspection, seems my sway bar bushings look shot.. So still have to get it up & really scope it..
& check ball joints, control bushings, etc, etc..
Only 37+ thousand on it, but built in Nov 2007.. So this is a first for mine.. So not complaining.
Blue- Will also scope the thin rubber were the engine cradle bolts up to the rad cradle
HHRnovice
Aug 18, 2020 09:06 AM
Doc brown
Jul 21, 2017 05:33 PM
SandiesHank
Oct 25, 2013 06:15 PM
fsc44
Aug 29, 2012 02:11 PM
barfan1
Aug 16, 2011 09:23 AM
