Hub / Bearing Assembly Cost Difference (abs vs. non-abs)
2 Attachment(s)
I read where ABS equipped hub assemblies are more expensive than the non-ABS equipped versions.
Why is it that whenever I look online at my local auto retailer's prices I find the non-ABS versions being more expensive? example.. autozone Attachment 26954 o reilly's Attachment 26955 |
the only reason i can think of is because the HHRs with abs are much more common than without. kinda like how some cars with power windows and locks are cheaper than the manual windows and locks. from the factory the HHRs are mostly abs as far as i know, the lt, 2lt, and SS, are all standard with abs. optional on the ls. so the hubs with the abs sensors would be cheaper by them being more common. i could be wrong about all of this:lol:
Originally Posted by badassbowtie
(Post 626364)
Just found a pair on ebay for 200 shipped. I did research on the part number which pulls up a Moog part. I'm thinking about pulling the trigger... this is the lowest that I found them at.
http://www.ebay.com/itm/PAIR-BRAND-N...66a790&vxp=mtr |
Originally Posted by helhedded
(Post 626367)
I happened to pick one without ABS and it's a LT model. ABS was optional.
If I understand from what some other posters have said in other threads - they have purchased the ABS units and removed the sensor. The web site "helhedded" provided the link to have a pair with sensors for $150 shipped.
Originally Posted by Sno White
(Post 626428)
Mine is without ABS and the hubs ARE more expensive than those with ABS. Everything mounts the same, just has the sensor.
I just picked up and installed a set of AC Delco's, less than $200 for the pair delivered and I got them in 1 day. Mine are also non ABS.
Installation was about 1.5 hrs for the pair. |
What kind of mileage do these hubs typically go bad? We have about 80,000 miles on our HHR LS with no anti-lock brakes. (the car has 0 options).
| All times are GMT -5. The time now is 10:26 AM. |
