HVAC control
Old Jul 4, 2018 | 09:03 PM
Lee3333's Avatar
HVAC control
Hi everyone. Wondering if anybody else has this problem. Every 2 years I have to change my HVAC switch panel. It begins by my losing the highest fan speed, then they all start to go. Also, the lights will flash intermittently.
I learned a trick-I break off the tabs on each end so I can install it without removing the radio.
Old Jul 4, 2018 | 09:36 PM
Never heard of anyone else having the problem.
High speed bypasses the resistor path to ground. Maybe the ground shorts to voltage? Or somebody tapped into the wrong wire.
I don't know... My 2007 is still running the original unit.
Old Jul 5, 2018 | 08:21 AM
X2 , eleven years and counting!
Old Jul 5, 2018 | 07:18 PM
hurlingmerlin's Avatar
mine's 10 years old, no issues with mine. is it possible someone boogered the wiring in that area putting in a head unit or other mods?
Old Jul 5, 2018 | 08:36 PM
Lee3333's Avatar
I am the original owner and all my wiring has been neat, so that shouldnt be an issue. Besides, when I replace the unit, it works fine for 2 years then begins to crap out. As I said, I lose some of the fan speeds one by one, and the lights for the HVAC panel begin flickering off and on intermittently.
If there was a problem with any of the wiring there, wouldnt the unit not work from the beginning? If seems to me like something internally is wearing out. Like the rotary switch. I noticed that when I jiggle it the blower turns off and on. Very strange.
Old Jul 5, 2018 | 09:58 PM
What I was thinking is maybe a LED or some other circuit got wired to the ground that goes to the switch and causing the switch to burn out. Something like that.
The switch supplies ground to the motor via the resistor pack. High speed is "no resistor". Arcing is what causes switches to fail.
Most people assume the switch would control the "hot" side.
So the question is: have you added any electrical wiring, no matter how innocent? Or changed any wiring.
Old Jul 6, 2018 | 10:08 AM
hellshotrod's Avatar
on my end i have seen them go bad and have sold a lot of them and most guys complain the high speed goes out and they have intermittent a/c or just runs hot air all the time maybe we run a/c to long in cali and that switch just to hot and burns out , ,,,,,
Old Jul 9, 2018 | 02:53 PM
Lee3333's Avatar
And you cant just buy the rotary control that is bad-you have to buy the entire panel with all the switches, and it costs $150
Old Jul 9, 2018 | 03:29 PM
GM P/N 22745744 w/RPO KA1 (heated seats) (14l GRAY)
GM P/N 22745745 w/RPO KA1 (heated seats) (19l EBONY?)
GM P/N 22745746 w/o RPO KA1 (14l GRAY)
GM P/N 22745747 w/o RPO KA1 (19l EBONY?)
EDIT: Just put these in the common part thread.
