Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
if that cover is still off can you take a picture straight down from above the cavity over the front timing chain guide? Is it damaged or the upper bolt broken?
This is what I can tell ya, approx 3 yrs or less ago the timing chain went , we purchased an aftermarket warranty when we purchased the vehicle so instead of doing the timing chain the dealership decided to put a new engine in. personally i didnt think they did that, rebuilds yea but brand new. paperwork states brand new 13 grand. this engine in my opinion never looked like a new engine. there has been crud and buildup all over underneath where as the one replaced was much cleaner. I know for a fact its not been low on oil at any time, couple times i went 5 or 6 thousand rather than 3 but since i read about how finicky this car is its been changed at 3000. i do not have a clue about that color, i have not looked insisde any other engines. the vvt solenoids are basicly new, when i say dirty they had some specks of crud on the screen very small amount ,cleaned rite off. From what ive seen online thats prertty common as well. I have used lucas with most oil changes maybe that has something to do with it. Unfortunately I didnt see these replys yesterday so its all back together. when i put ,y finger on the chain and pressed down there was no play at all really so im assuming if stretched or anything wrong i would of felt it. another thing is like today i just got home and drove 50 miles and the car felt good. what im talkimg about is not something i always feel, my wife says otherwise and she drives it much more than me.I took this yesterday but its a poor picture.
I honestly dont know if your being sarcastic or not. in regards to changing oil I said in the posts above i had done it every 3k to 5k miles. I dont think i ever went over 5k. That color I believe would be from using Lucas, I do not know of any other reason. while under warranty dealership handled all the maintenance, since then i went to penzoil where they swear by Lucas. thats neither here or there, will seafoam clean this? is this a problem? unless i missed it i feel like i got some critisism which is fine keeps life interesting but i dont think ive gotten much along the lines of help. on the second issue i posted service esc and abs light coming on for seconds than going off, could that be a bad or old battery? i havent replaced that since owning this car.
