i have got a few problems
Old Jan 23, 2008 | 06:56 PM
dandhcomputers's Avatar
1. the brakes squeal
2. some times i start my car the engine rattles for only a few sec.
3. the front struts make a thumping sound under my feet you can feel
I might start lemon law on the car .
the car only has 3245 miles on it . when i first got the car the front disks need to be replace . the car only had 100 miles on it. the last time i had my car in the shop that could not make the brakes make the noise i took the tech on a test drive . .They replaced the outside temp sencer because it went out and did not work . that had to flash the ecm and the bcm to fix the fob problem and replace my key and the fob because the fob could start 6 out of 10 cars on the dealers lot .
I love my little black betty hate to see it go if they cannot fix her
what do you all think i should do ???
thanks in advance
David
Old Jan 23, 2008 | 08:11 PM
pitbull76's Avatar
Seriously I would try another dealer for your current problems. You may get better results.
Old Jan 23, 2008 | 11:28 PM
SIRESMERPH's Avatar
yep
Old Jan 24, 2008 | 06:14 PM
the only problem is that the next dealer it about 30 mins away from my house
Old Jan 24, 2008 | 06:39 PM
Firewatcher's Avatar
30 minutes away is a big deal? Wouldn't be to me if my dealer was doing a lousy job and I wanted another opinion.
Old Jan 24, 2008 | 06:44 PM
MWG2's Avatar
My brakes squeal too. I had the rear drums cleaned today. They had some dust but after the cleaning, they still squeal. If they continue...back to the dealer. The car has 2437 miles on it...still new.
Old Jan 26, 2008 | 09:44 AM
hhrcrafty's Avatar
Originally Posted by dandhcomputers
the only problem is that the next dealer it about 30 mins away from my house.
Are you kidding me?!
Seriously, I had to drive TWO HOURS to another GMC dealership when I had my Sonoma because the local service department was utterly incompetent.
I would doubt that you have much of a lemon law claim because none of those problems have actually rendered the vehicle unusable for an extended period of time. Take it to another dealership and see if they can troubleshoot any of those problems, although with the exception of the brakes it doesn't really sound like you're having much of any problems with the car.
Old Jan 26, 2008 | 10:03 AM
got another problem went to get into the car and backed out fo my drive way and put it in drive and it would hardly go .. Going to the shop monday . driveing my vintage car to work for now
Old Jan 29, 2008 | 03:02 PM
used lemon law and i had the dealer to order an 08 ss that looks like my old one
Old Jan 29, 2008 | 07:17 PM
rob-cyn's Avatar
Good luck, I hope it works out for you as I have never heard of anyone having good fortune with the lemon law.
