I have a weird problem
So my hhr will not start, OBD will not connect to my scanner, windows wont roll up, radio doesn’t work and locks won’t work. Battery is ok. Turn the key to aux nothing. Turn the key to run lights on the ipc come on. Car shut off at a light and that was it. Help
Welcome.
What year and model/engine and mileage are we talking about? How exactly do you think the battery is ok? |
Originally Posted by whopper
(Post 870297)
Welcome.
(Post 870297)
Welcome.
https://cimg4.ibsrv.net/gimg/www.che...b6ce9d6799.png
Assuming the battery was tested after this started; check the large red wire connecting to the under hood fuse box, make sure it is firmly attached and cleaned. Why do you ask about the BCM? Did something happen that you are leaving out? |
Originally Posted by donbrew
(Post 870302)
Assuming the battery was tested after this started; check the large red wire connecting to the under hood fuse box, make sure it is firmly attached and cleaned. Why do you ask about the BCM? Did something happen that you are leaving out? Windows, locks, dlc not working. DLC has power. |
So? What are you calling DLC?
The BCM gets it's power from the maxi fuse next to the battery the rest of the car gets it from the aforementioned red cable. |
(Post 870304)
The BCM gets it's power from the maxi fuse next to the battery the rest of the car gets it from the aforementioned red cable. Data link connector (obd) |
(Post 870304)
Ignition recall?
