I have a weird problem
So my hhr will not start, OBD will not connect to my scanner, windows wont roll up, radio doesn’t work and locks won’t work. Battery is ok. Turn the key to aux nothing. Turn the key to run lights on the ipc come on. Car shut off at a light and that was it. Help
Assuming the battery was tested after this started; check the large red wire connecting to the under hood fuse box, make sure it is firmly attached and cleaned.
Why do you ask about the BCM? Did something happen that you are leaving out?
Windows, locks, dlc not working. DLC has power.
