I need help. p0442
Old Sep 12, 2014 | 06:09 PM
zachrf's Avatar
I need help. p0442
p0442 just came on a week ago. idles about 100-200 more than usual and obnoxious rasp ONLY when accelerating. not in netural not in park. hoses in engine bay look fine. its not the gas cap. any input is appreciated I dont wanna spend hundeds for a easy fix
Old Sep 12, 2014 | 07:40 PM
Lucky's Avatar
The code you have is saying that there is a leak detected in the evap system.
Could be a leaking or loose gas cap, leaking vent valve or purge valve, or any other leak in the hoses or fuel tank.
Most common are the gas cap and or the vent valve.
The noise that you mention could be a exhaust flex pipe leaking.
Old Sep 12, 2014 | 09:53 PM
zachrf's Avatar
checked gas cap and all looks well so ill be checking the evap canister area and hopefully somethings just loose. and ill look into the flex pipe thank you
Old Sep 13, 2014 | 06:00 AM
The flex pipe will also cause the code!
Old Sep 13, 2014 | 06:12 AM
LawDog88's Avatar
I can confirm the flex pipe makes a terrible sound when busted. Mine was replaced under emissions warranty. Thought with yours being an 06, I doubt yours could be.
My work computer won't let me access GMPartsdirect.com but you could go there and do a parts search for the flex pipe and see what it will cost for your specific vehicle.
Old Sep 13, 2014 | 06:31 AM
zachrf's Avatar
Thank you guys I will look into it!
Wolfie
Oct 9, 2010 08:54 PM
Wolfie
Nov 22, 2009 06:45 PM
