I want A/C on when I start the engine
Wish I had seen this post before I worked on my car tonight, but what would happen if you ripped of the "waterfall" dash bezel, then took of the panel with the two Outside/recirc cables and switched them? I am not sure if the pinouts are the same, but I think the wire harnesses were similar in shape with different colored wires. Then of course, you would have to know that recirc is actually outside air and vise-versa.
And some people make assumptions about other's intentions. I hadn't noticed that my previous post was cut short for some reason. It should have had "You might get a faster response by starting a new thread. At least, it helped me when I needed info from the people here"
I only saw what I saw! Had no idea what was "Cut Off" from your post!!
