Ignition Coil Pack Mount Bolts
Hey all. 2006 HHR LT 2.2. I need the part number for the mount bolts for the Ignition Coil Pack. It's the 4 bolts. If you have the original, I believe it shold say 8.8 on the head of the hex bolt. These bolts go directly into the valve cover. May have over torqued one when I installed it. Thanks! I have looked high and low on the part blow-outs images and nothing shows the 4 bolts.
Just take one of the remaining good bolts and go to your local hardware store. Find a match.
Or, go to your local auto wreckers and scrounge one up.
Or. PM member hellshotrod. He's got a yard full of HHR parts. He could send you one if he's got one in stock.
