I'm not sure if my A/C compressor is engaging
Old Sep 2, 2024 | 11:17 AM
Or more. R&R the compressor is just part of it. Recovery, evacuate and recharge is the other. And most AC shops will recommend to replace other things that may have gotten compressor debris in them. Expansion valves and such.
Done correctly, it’s never just as simple as a compressor swap.
I’d call around and get some quotes.
Old Sep 2, 2024 | 11:19 AM
You could save a bunch by doing the wrenching yourself; let a pro do the evacuation and charging. Technically illegal to release the freon into the atmosphere.
Old Sep 2, 2024 | 07:53 PM
BigT's Avatar
I had not thought of it before but should I be getting a check engine light for any of these A/C problems?
Old Sep 2, 2024 | 08:29 PM
No. But some CELs can disable the AC. Some will make the automatic transmission shift hard.
Old Sep 5, 2024 | 01:03 PM
BigT's Avatar
So, It seems I got off easy. I did, of course, have to pay for the evac and recharge and diagnosis which was $325.00. The reason the A/C wasn't working was the relay for the Compressor was bad. Total bill was $390.00. I appreciate the help and suggestions I got from those who responded. Thanks.
Old Sep 5, 2024 | 01:56 PM
Great news it’s fixed! Enjoy the ride!
Old Sep 5, 2024 | 02:29 PM
From post #6
couldn't it be a relay
My bet is it stops working soon. More likely you t-stat is stuck ope.
Old Sep 5, 2024 | 09:19 PM
BigT's Avatar
Originally Posted by donbrew
From post #6
Come on, man.
Old Sep 6, 2024 | 07:42 AM
He’s got a knack of being right, but at least you’re gonna know to change the thermostat, ACDelco 131-158 180 F degrees.
LON
Jul 29, 2023 08:06 AM
tooter1
Jul 29, 2022 03:10 PM
drscott
Jul 1, 2019 11:24 AM
toyman
Nov 13, 2010 08:33 AM
jerij
May 30, 2006 10:58 AM
