Interior Rattle Question
Old Mar 24, 2009 | 08:44 AM
imagepower's Avatar
Originally Posted by hyperv6
The guy who changed out my windshield in my old truck gave me two rolls of it and said it was good to keep on hand. There were many uses for it.
It is a roll of rubber with a paper strip on it so it will not stick together.
I have used it for many things over the last couple years.
You should be able to get it at a glass shop. There are other things that would work too but I had this and it worked fine. It takes very little to fix the console. So don't buy too much. Just a few inches would do.
Thanks
Old Mar 24, 2009 | 08:22 PM
Cokeybill's Avatar
Originally Posted by Kevin Schneider
I have a 2008 HHR SS and I have a rattle coming from the center console area. The sound is reproducible at highway speeds on smooth or rough pavement. I have had the console apart but could not find the source of the rattle. The sound is not the front tray because I have already fixed this rattle. It sounds like it maybe coming from the parking brake lever. Does anyone have any suggestions.
Did you check the chrome molding around your shifter, mine was loose and could just lift it out.
Old Apr 30, 2009 | 09:38 AM
jerSSey HHR's Avatar
Can you guys give me some more detail as to where to apply this rubber? Do I need to remove anything or take apart portions of the dash to apply it? Pics would really be helpful if it's not too much to ask. This rattle is driving me nuts and I know the dealer is not going to be able to fix it correctly, so I'd rather just do it myself.
I don't want the rattles to ruin my otherwise great ownership and driving experience.
Old Apr 30, 2009 | 09:43 AM
Did you reattach it and how?
Old Apr 30, 2009 | 01:22 PM
Cokeybill's Avatar
I just added some foam like the air conditioning you put in the windows at home. Works gr8.
Old Apr 30, 2009 | 04:02 PM
That's what I was going to use, but I'm not sure where to put it.
Old Apr 30, 2009 | 04:08 PM
pitbull76's Avatar
One possible rattle area is the trim around the radio. Both my old 06 and my 08 SS were afflicted by that rattle. Look in the how-to guide area in the radio removal thread to see how to remove and replace the trim piece. Some sound insulation(furniture felt ) on the back of that piece where it contacts the rest of the dash helped many of the rattles in my car.
Old May 1, 2009 | 07:24 AM
Cokeybill's Avatar
Outer edges of the clips that don't fit.
Old May 1, 2009 | 08:02 AM
hyperv6's Avatar
If you look under the under side of the console top it has 4 places that rest on the console base when it is in place. they rub and make noise.
I put the rubber [you can try the foam] on those places and it should fix the console rattle.
The 3M time tape will also work too just don't use a lot. You may need to remove it someday.
Old May 1, 2009 | 08:16 AM
Thanks - I'll try to get under there this weekend.
