intermediate shaft grommet
Old Sep 18, 2020 | 12:32 PM
tack's Avatar
HI. I installed an intermediate shaft on my 2009 Chevy. I am having trouble getting the firewall grommet back in place. Is there a technique or trick to doing this?
Thanks
Old Sep 18, 2020 | 12:47 PM
Insert the top then squeeze the middle and push into the oblong hole, use a 3/8 drive 12 inch extension and push the bottom in.
Old Sep 18, 2020 | 05:02 PM
tack's Avatar
I got the grommet in after I discovered the oval is cut off center in the firewall. Your directions helped. Thanks.
Old Sep 19, 2020 | 06:28 AM
I’ve wrestled a few times with that grommet happy to see you got it back into position.
Old Dec 19, 2021 | 04:24 PM
SwaintaN's Avatar
I know this is an old thread.. but I'm at my wits ends with this damn shaft boot/grommet... nothing I've done in 2 hours had made it go on... ahhh!
Old Dec 19, 2021 | 04:42 PM
Rest , regroup, attack it a dawn in the morning , try a little bit of Dawn to lubricate the rubber and help it slip into position.
Old Dec 19, 2021 | 04:43 PM
SwaintaN's Avatar
I sprayed lube on it to try, I'm beyond frustrated... like really a boot is gonna hold me up from finishing this car..... ugh.
Old Dec 19, 2021 | 04:57 PM
This approach has worked for me , severs times
Old Dec 26, 2021 | 12:10 PM
SwaintaN's Avatar
I finally did get it, got frustrated and ending up using 4 ft crowbar to get it...
Old Dec 26, 2021 | 12:11 PM
Awesome, now don’t touch! It’s happy where it is!
