is it just me?!
Old Mar 27, 2010 | 11:47 AM
bowtieboy68's Avatar
is it just me?!
Has anyone else run into not being able to jumpstart a car from your HHR?
I recently got my 95 S10 out of storage and had to try and jump the battery.
I tried getting a connection from the leads (on the HHR) under the hood and went as far as trying from the battery itself!
Old Apr 8, 2010 | 10:32 PM
UPDATE: so i'm guessing that after 120 views and no comments, i seem to be the only person that can't jump start another vehicle using my HHR.
guess i'll dig further to see what the issue is.
Old Apr 8, 2010 | 11:20 PM
edstacoma's Avatar
Haven't tried it don't know why it wouldn't work
Old Apr 9, 2010 | 10:33 AM
Cajun's Avatar
I jumped my Chevy 4x4 pickup when the battery failed...no problems...
Old Apr 9, 2010 | 10:42 AM
SmootHHR's Avatar
Could also be that the battery in the s10 is just too dead. Might wanna have it tested.
Old Apr 9, 2010 | 01:44 PM
Smooth:i'd tried to jump a buddy's car last year when his was dead.
The HHR couldn't connect, so i had to get my S10, which worked.
very odd
Old Apr 10, 2010 | 12:07 AM
Marzipan's Avatar
Did you follow the procedure set out in your owner's manual?
Old Apr 10, 2010 | 07:56 AM
87silver's Avatar
For S&G's, I tested voltage at the specified positive connection at the underhood fuse block and the ground point on the shock tower and clearly getting about 12.8-13.2V (engine not running).
Maybe there's an issue with the output of the positive connection? Did you check voltage with a meter?
