Key Fob Issue
Old Aug 11, 2014 | 07:59 PM
Tyler Harvey's Avatar
Key Fob Issue
My wife has a 06 LS. The key fob works fine expect for the locking button. You have to hold down the locking button for at least five seconds. I checked the search for this related issue and found nothing. I cleaned the connections and buttons with alcohol and tried using a eraser. Nothing has improved. Wondering if I should disconnect the battery? Also thinking the fob may be worn out. Any suggestions?
Old Aug 11, 2014 | 08:11 PM
Yup, sounds like it is worn out. Not sure what ones you already looked at, but there are numerous threads regarding repairing the worn out "carbon" buttons (with tin foil, or , or buttons scabbed from an old tv remote or calculator). Several also discuss purchasing fob rebuild kits (to replace the case and keypad) at most auto repair shops.
I doubt disconnecting the car's battery will do anything positive in your case - it's the fob that is the problem.
Old Aug 11, 2014 | 08:22 PM
Lucky's Avatar
There is keyless fix which repair the contacts. Or you can get replacement rubber pads on ebay.
Both of these fixes do not require dealer programing because you reuse the board from your old fob.
http://www.keylessfix.com/
Old Aug 12, 2014 | 06:26 AM
Something must be wrong with the search if you couldn't find anything. I have noticed some odd behavior lately.
hint: try "keyfob".
Old Aug 12, 2014 | 04:00 PM
Thanks Whopper, I tried the tin foil last night and they both work like brand new! She's so happy and says thanks as well. Happy wife, happy life.
can2blue
Jul 11, 2013 03:34 PM
Thisstrangeengine
Aug 30, 2011 11:39 PM
gmdealerguy
May 22, 2011 01:25 PM
LewiSS
10
Oct 8, 2010 01:29 AM
gcsd3742
Jul 25, 2008 11:10 AM
