Key Fob Replacement
Old Jan 12, 2022 | 07:22 AM
jc102's Avatar
Key Fob Replacement
Hey everyone,
I didn’t realize my 2011 Chevy HHR should have come with a key fob when I bought it from a used car lot. Is there a way to buy a replacement for my car?
Old Jan 12, 2022 | 07:35 AM
Look in the tubs in the back behind the rear seats , sometimes they are left in there or in the glove box or the cubby on top of the dashboard, if not there,
There are Several ways to obtain a fob, order from your GM dealership, then have them program it to your HHR. Expensive method!
Then there’s the Dorman kit with a program module for the fob that comes with it, and you can program up to 3 devises, so if you order 2 OEM GM fobs you can program them, question is do you need 3 button or 4 button fobs? Do you have remote start, check in the DIC , look at the hood latch for a wire harness. Was your 2011 a rental car , then for sure it won’t have RVS
Old Jan 12, 2022 | 07:55 AM
2011 RVS was not standard equipment.
Lock + Panic = RVS, so the extra button is nor "required", except on Chinese fobs. I recommend Genuine GM fobs.
Old Jan 12, 2022 | 09:26 AM
jc102's Avatar
Thanks, I will reach out to a local dealership and see if they can help.
Old Jan 12, 2022 | 04:36 PM
heathenhhr's Avatar
the previous rental thing is not 100%, I have an ex-rental, and it -does- have RS
you can PM me the last 8 of your VIN and I can look up your OEM# for you tomorrow at work
Old Jan 13, 2022 | 07:37 AM
PulpFriction's Avatar
I suggest getting the 4-button fob even if you don’t have remote start. The fourth button won’t hurt anything, and might be useful for another car some day. Or even more buttons, on the same principle.
Old Jan 13, 2022 | 07:59 AM
All Genuine GM fob circuit boards (guts) have the fourth button contacts.
mwatwell
Apr 18, 2021 08:41 PM
Solotreker
Mar 22, 2018 03:30 PM
macarchie
Aug 10, 2012 04:04 PM
MaryJane
Apr 3, 2011 11:44 PM
TheBug
Jul 1, 2008 07:31 PM
