Key Ignition
Key Ignition
The key isn't supposed to come out if the car is On or if the gear is in anything other than park, right?
Because mine doesn't. It comes off at anytime when I pull it out.
What can be the problem?
P.S, (recall hasn't been done)
I doubt you’ll find a GM dealership in your country that will preform the recall work, all these years later.
https://plants.gm.com/media/us/en/gm...-ignition.html
You might find the pieces to replace in the recall.
It was a good 20km drive.
