No power- key stuck in ignition.
Old Mar 4, 2016 | 05:07 PM
hawky220's Avatar
My key fob wouldn't work at all so I manually opened the door.
I put the key in the ignition and I got nothing. No lights. Nothing.
Now the key is stuck in the ignition. Cannot move the car out of park either.
HELP!!
Old Mar 4, 2016 | 05:18 PM
Key Stuck
If you enter that in the search window above, you'll get some good information on this problem.
Old Mar 4, 2016 | 05:29 PM
Column Lock Release
For vehicles with an automatic transmission, the following procedure allows the ignition to be turned to LOCK/OFF and ignition key to be removed in case of a dead battery or low voltage battery.
(the step by step is in your owners manual)
Old Mar 4, 2016 | 05:35 PM
https://www.chevyhhr.net/forums/gm-r...14632-a-52498/
Among many others.
Old Mar 4, 2016 | 07:32 PM
hawky220's Avatar
Thanks everyone! I'll be calling the dealer first thing in the morning- They replaced the ignition switch when it was recalled- not sure if that's the problem or the shifter from what I'm reading. Either way- I hate being without a car for a stupid reason.
Old Mar 4, 2016 | 07:54 PM
They sent a letter out.
Old Mar 5, 2016 | 08:41 AM
hawky220's Avatar
Well- it turns out it was a dead battery. Anti theft detterent causes the key to lock in the ignition. I called AAA this morning and I'm back in business!!
Old Mar 5, 2016 | 08:44 AM
DwRed2LT's Avatar
Glad you got back on the road.
Have had the key stuck with dead
battery more than a couple times.
Old Mar 5, 2016 | 09:51 AM
Glad it's fixed , a dead battery can cause a myriad of problems, like the stuck in the ignition key deal!
AAA to the rescue! When I have them address this problem a few years ago while on vacation in Florida , the guy was very good to deal with and the battery is still in the HHR it's 5 years next month
Old Mar 5, 2016 | 09:59 AM
Strange you didn't notice a dead battery.
If you need an owners manual; here's a link
https://www.chevyhhr.net/forums/gene...-manual-3074/?
