key removal issue
key removal issue
My '07 HHR won't let me turn the key all the way off to the lock position or remove the key. Is this a common problem, and is it an easy fix? I'm pretty sure it has something to do with the shifter, because I can also shift into any gear while the var is off. Any help out there? Thanks, Izzy
try rocking the shift knob up and down while in park. Also make sure nothing is in the way of the shifter! That happened to me! This has been an issue though. Use the Search function to find out more.
If the car is on and you press the brake pedal, can you hear a clicking sound from the shifter area? If you don'y hear that I would check a fuse maybe that powers that, maybe it's blown. also there maybe a problem with the shifter solenoid
