Keys Stuck in Ignition
Old May 27, 2008 | 12:52 PM
Leon's Avatar
I think they are going to take care of it for me.
Old Jun 15, 2008 | 07:56 PM
$ilverHHR's Avatar
Originally Posted by Harpozep
We had ours repaired under warranty. Stupid silly problem, but it exists.
Tell your dealer about it and say there is a TSB on it. That should take care of things.
Im not good at deciering acronyms, what is TSB in this case...
TSB Tall Shiny Building
TSB Tangential-Sphere Bound
TSB Technical Service Bulletin
TSB Technical Services Building
TSB Technical Staffs Branch (UK)
TSB Technical Support Branch (National Hurricane Center)
TSB Tecmo Super Bowl (video game)
TSB Tecnologías para la Salud y el Bienestar (Spanish)
TSB Telecom Support Board (NASA)
TSB Telecommunication Standardization Bureau
TSB Telecommunications Standard Block
TSB Telecommunications Standardization Board
TSB Telecommunications Systems Bulletin
TSB Tepid Sponge Bath (fever management)
TSB Tepper School of Buisness
TSB Termination Status Block
TSB Textiles Surveillance Body
TSB The Spiriting Board
TSB Theater Staging Base
TSB Thrift Savings Bank
TSB Thrust Sector Blower
TSB Time-Share-Börse
TSB Toronto School of Business
TSB Total Serum Bilirubin
TSB Towed Sonar Buoy
TSB Traffic Safety Board
TSB Training Support Battalion
TSB Training Support Brigade
TSB Transmission Synchronizer Brake
TSB Transmit Silence Bit
TSB Transportation Safety Board of Canada
TSB Transportation Service Bulletin
TSB Transportation Services Branch
TSB Transportation Support Battalion
TSB Trunk Signaling Buffer
TSB Trustee Savings Bank
TSB Truth Supervenes on Being (philosophy)
TSB Trypticase Soy Broth
TSB Twin Side Band
TSB Technical Services Board
TSB Technical Support Bulletin
TSB Translation Storage Buffer
TSB Transport Service Bridge
Old Jun 15, 2008 | 08:00 PM
shaginwgn's Avatar
TSB=Technical Service Bulletin
Old Jun 15, 2008 | 10:13 PM
Aw, you knew it all along. Bet you were just testing us..........
It was the only one you had on your list twice. #3 and #41.
NOW HOW MANY OF YOU ARE GOING TO GO AND ACTUALLY READ THE LIST?
Old Jul 18, 2008 | 03:58 AM
LARRYREDHHR's Avatar
19,000 Miles Mi 2006 Just Did It. Can't Get The Key Out, Used The Button, Will Be In For Service Wednesday
Old Oct 29, 2010 | 12:44 AM
  #26
JuneMcfHou's Avatar
Angry Car Won't Start Key Stuck in Ignition
I am new to this forum, so please bear with me.
I have had this happen to my car more times than I can count. I got the car used and suspect that is why the first owner sold it. To make matters worse, I have had both the shifter and the steering column replaced (extended warranty and insurance paid for it) to the tune of almost $3,000 dollars. It is still doing it. I have to call a wrecker when this happens. The last one got it started because he was able to wrestle the steering wheel out of a locked position. I do not have that kind of strength. I had to wait 1-1/2 hours for the wrecker. I love the looks of the car, but I am one unhappy camper about it not starting. I don't expect to have to hold my mouth in a certain way and have the sun shining from the east to start the stupid car.
June
Old Apr 19, 2013 | 04:59 PM
  #27
Chevy said they replaced a selenoid, I saw that the SHIFT CONSOL had been opened and greases. the mechanic said the cable was the issue, not releasing / alining the lock. I found on real cold days sometimes I have to slam the shifter into park.
other than this the car has been great, no noises as others have had.
Old Jul 6, 2013 | 03:17 PM
  #28
blacky's Avatar
No power means battery is dead.
If battery is dead, key will not come back out of cylinder.
Others mentioned trap door under steering column to release key.
Energizing system as in boost/jump will restore normal key removal.
Old Jul 6, 2013 | 04:08 PM
  #29
howardt's Avatar
Ignition problem
'07 HHR After quite a few times plus way too much for a new ignition switch we finally leaned about a locked steering wheel. Anytime it was locked the key will not turn. Just jiggle the steering wheel back & forth while pulling on the key & out it comes ! Then works normally till the next time. You can turn the wheel right or left anytime to lock the wheel too !
Old Jul 6, 2013 | 04:43 PM
  #30
MsBecky's Avatar
That would be correct !!!! Dead battery and key will not come out . Energizing system as in boost/jump will restore normal key removal
Problem solved
