Knocking
Old Jan 19, 2007 | 03:45 PM
Snoopy's Avatar
Old Jan 19, 2007 | 04:21 PM
tireman1554's Avatar
Like the Super Bowl Shuffle
Old Jan 19, 2007 | 05:31 PM
Black Rose's Avatar
Originally Posted by Alzonie
What exactly is "Piston Slap" anyway? It sounds like something you might have on an old worn out engine.
I had it on a brand new engine. After 24,000 miles, the pistons had damaged the walls of the #2 and 4 cylinders to the point that the engine was scrap metal.
Piston slap is when the piston moves side to side in the cylinder wall due to too much clearance between the piston and the cylinder wall, resulting in a knock or slap sound. This came about for GM when they switched to short skirted pistons (yes, apparently pistons are wearing mini skirts now ).
BTW, the piston skirts in the 2007 2.4 VVT motor were redesigned:
Optimized Piston Skirt
Ecotec 2.4L VVT pistons have been redesigned with a slightly different profile. The piston skirt has been optimized with a slight barrel shape, helping to smooth its glide through the cylinder bore and reduce lateral movement. The new pistons reduce operational noise, particularly during cold starts, and enhance overall smoothness.
Old Jan 19, 2007 | 05:49 PM
Alzonie's Avatar
[QUOTE=Black Rose;11457
Thanks for that! Sounds like an Engineering "BooBoo" on somebody's part! You'd think they could have seen problem coming.
Old Jan 19, 2007 | 10:12 PM
Black Rose's Avatar
It's been happening on certain V6 and V8 motors since 1999, so they have seen it coming, they just ignore it due to the amount of money it would cost them to fix it.
grannydeb
May 8, 2014 07:35 AM
SwaintaN
Mar 25, 2014 12:16 PM
Mischevious
Oct 10, 2012 02:37 PM
DTHarris
Nov 11, 2011 02:58 PM
ginginee
Feb 3, 2010 09:42 PM
