Location of Camshaft sensor?
Old Sep 12, 2017 | 01:07 PM
syllinx22's Avatar
My friend has a P0340 code and wants to know how to tell which camshaft sensor it is.
Any hints would be nice.
2009 hhr 4 cyclinder flex fuel.
Old Sep 12, 2017 | 01:19 PM
Before they start throwing parts at it they should checkt the wires and connections.
Old Sep 12, 2017 | 01:27 PM
syllinx22's Avatar
Thanks everything is snug. I will try to check the wires today.
Old Sep 12, 2017 | 02:06 PM
Take a look at all the connections per
https://www.obd-codes.com/p0340
And welcome to the site!
Old Sep 13, 2017 | 05:00 PM
db2006's Avatar
The code is saying the camshaft position sensor isn't giving the expected reading. It could be a sensor or wiring but it is most often a camshaft position actuator solenoid valve not working properly. The camshaft position sensor is not too expensive and quick and easy to change. The solenoids are more expensive and slightly more difficult to replace. They are under the air cleaner and in an area that mice sometimes like to build nests so it might be worthwhile to check to see if the wiring has been chewed. If they need to be replaced, it is best to replace both.
Old Sep 13, 2017 | 06:22 PM
J W Davis's Avatar
Takes longer to remove the air filter than change both solenoid valves.....
Old Sep 13, 2017 | 07:11 PM
syllinx22's Avatar
So far it seems ok.
Friend at a auto store let me try new camshaft sensor. Engine quit bucking immediately. Seems to be fixed.
Old Sep 13, 2017 | 08:12 PM
Good! that is rare but pretty specific DTC.
Old Sep 16, 2017 | 08:54 AM
db2006's Avatar
Thanks for letting us know. Hope it holds up.
Old Sep 16, 2017 | 05:21 PM
Which side was bad, intake or exhaust?
