Locked...
Old Aug 22, 2012 | 10:52 AM
Beany's Avatar
Locked...
Another issue I'm having with my HHR is the shifter (auto) locks in park and it takes several tries to get it to shift.
Old Aug 22, 2012 | 11:01 AM
Search function at the top of the page - search for "shifter locked" - lots of info available.
Old Aug 22, 2012 | 11:40 AM
ChevyMgr's Avatar
Kind of rare on your model year, but probably has soda type fluid spilled inside of shifter causing the mechanism to stick.
Old Aug 22, 2012 | 09:38 PM
Zagohhr's Avatar
Probably the lever of the knob is not reaching/pushing the "plastic shaft" to make the changes. You would disassemble and add and spacer between. I had the same issue too and this fixed it.
Old Aug 22, 2012 | 11:17 PM
geg's Avatar
geg
x2
I have it a couple of months ago. Damned Fanta spilled.
The problem was solved with the help of Mr. Whopper and spray WD.
I just removed the cover of selector, found stopper (small white plastic element) and sprayed it.
leilani
May 3, 2011 05:01 AM
catdaddy137
Feb 16, 2009 03:35 PM
mitzkity
May 14, 2007 05:47 PM
john_a_basilio
Nov 22, 2006 04:03 PM
