Loose cigarette lighter socket
So I'm just really noticing, but my cigarette lighter socket is wiggly. Mostly on like.. The right side. Every time I pull something out of it I'm worried it's gonna pull the whole thing out. Is there a way to tighten this?
It's mostly the retainer ring that breaks
https://www.chevyhhr.net/forums/atta...la-1235275.jpg Replacement for the power OEM 25774623 Auxiliary Accessory Power Outlet Receptacle for GM New Replacement for the retainer GM OEM Center Console-12V Power Outlet Retainer 25749635 |
Originally Posted by Oldblue
(Post 825805)
it is a friction fit from the factory. If somebody tried to mess with it without the "special tool" they usually break either the hole or the holder in thingy.
There are 2 tabs on the retainer that go into holes in the outlet. The tool goes around the receptacle and pushes the tabs out. Are you aware there is a difference between cigar lighter and power outlet? Don't put a cig lighter in a power outlet! Unless your car came with the "Smoker's" package you have a power outlet from the factory. I doubt super glue would do it. |
X2 , if I thought glue would be a viable solution, I would have advised you so.
It's your car , but you should repair it properly |
Originally Posted by donbrew
(Post 825810)
There are 2 tabs on the retainer that go into holes in the outlet. The tool goes around the receptacle and pushes the tabs out. Are you aware there is a difference between cigar lighter and power outlet? Don't put a cig lighter in a power outlet! Unless your car came with the "Smoker's" package you have a power outlet from the factory. I doubt super glue would do it. Thanks! |
You can’t get one , obsolete, use slip joint pliers be careful
(Post 942002)
Dorman 56457 Lighter Socket And Removal Tool Compatible with Select Models https://a.co/d/9V1zZ6S |
Yes, that will do it, I didn’t know Dorman was reproducing the tool.
What it does is releases the spring clips on the plastic retainer so they don't break. Installation is simply a "click".
