Loose cigarette lighter socket
So I'm just really noticing, but my cigarette lighter socket is wiggly. Mostly on like.. The right side. Every time I pull something out of it I'm worried it's gonna pull the whole thing out. Is there a way to tighten this?
It's mostly the retainer ring that breaks
Replacement for the power
OEM 25774623 Auxiliary Accessory Power Outlet Receptacle for GM New
Replacement for the retainer
GM OEM Center Console-12V Power Outlet Retainer 25749635
it is a friction fit from the factory. If somebody tried to mess with it without the "special tool" they usually break either the hole or the holder in thingy.
There are 2 tabs on the retainer that go into holes in the outlet. The tool goes around the receptacle and pushes the tabs out.
Are you aware there is a difference between cigar lighter and power outlet? Don't put a cig lighter in a power outlet! Unless your car came with the "Smoker's" package you have a power outlet from the factory.
I doubt super glue would do it.
Thanks!
ah, so this won't work?
Dorman 56457 Lighter Socket And Removal Tool Compatible with Select Models https://a.co/d/9V1zZ6S
weekendwarrior
01-20-2011 08:35 PM
