Lost
Old Jan 14, 2020 | 04:47 AM
Cat Man HHR's Avatar
This problem is making me dizzy.
You only worked 3 hours and the car was dead ? Yes first thing I would say is battery.
Start again. Give numbers on battery before and after testing it. Don't care how old it is.
Are there any codes stored in the ECM even though check engine light isn't on ?
Did you remove the negative battery cable for 30 minutes and reconnect to see if that cured your problem ?
Why do you have an aftermarket remote start ? Did you install it ? By the way nice splicing on those wires. (electric tape is my friend, not.)
What type of shop do work in that has so many fuses on hand ? Is it a stereo shop ?
"Inquisitive mines want to know"
Old Jan 14, 2020 | 05:34 AM
Joe Giacobe's Avatar
Originally Posted by donbrew
The pink on in the blue circle comes from the run/crank relay
the car did not come with the remote start the car was sent out to Northeast light and sound and they installed it here in Hazleton Pennsylvania I took the module back to them they tested it on their computer it brought up all the cars information when they plugged it in so that's not the issue on the fuse panel inside the vehicle in the picture posted there is one large red dark red wire that goes into the side I believe it's some type of feed wire to the fuse panel once I applied power using a Power Probe everything came back so I connected a jumper wire from one of the other wires there that have power to that one just so I can get the car to start and drive it to the dealership so they can perform recall of the ignition switch which was scheduled for today... They are not going to look into the issue I told them I will take care of that myself I just have to find out what feeds that wire its power I'm wondering if it's an old school type set up where the power itself comes from one of the starter wires and feeds that panel I won't know until I get the car back later today work tomorrow to look into the issue further... if anyone has any further ideas or maybe you can shove me in the right direction please feel free to PM me any help would be appreciated
Old Jan 14, 2020 | 06:15 AM
It's been posted a couple of times by Donbrew that the BCM (inside fuse box) gets it's main power from the 50 amp Maxi fuse that is back by the battery.
Don asked you before if you checked that fuse but you never answered.
*warning* Posting your phone # on an open forum. Have you got some kind of cyber suicide wish ?
Old Jan 14, 2020 | 06:33 AM
yes the fuse by the battery is also been checked and replaced there is power there as for the phone number I said junk throw away phone no big deal
Old Jan 14, 2020 | 06:51 AM
Then you need to find why the power is not getting from the Maxi fuse to the BCM. Start at that fuse and check forward till you find the break.
Old Jan 14, 2020 | 07:20 AM
  #26
thax as soon as it comes back to the shop ill look into it and keep ya posted
Old Jan 14, 2020 | 08:11 AM
  #27
Junk phone or not, our policy is no phone numbers or email addresses are to be posted to protect from scammers and spammers and other information privacy issues!
Please use the PM system only ! That’s why it’s there!
Old Jan 14, 2020 | 09:56 AM
  #28
dident know..kinda new to this whole deal...still trying to fig out this forum...
Old Jan 14, 2020 | 10:24 AM
  #29
The 2 red/blk wires on the left are on fuses #4 and #6 on the under hood fuse box. I con't figure out where the middle red/wht one goes.
Old Jan 14, 2020 | 11:22 AM
  #30
RainmanQQ's Avatar
Joe: I am right down the road from you in Drums, PA. We just picked up a 2006 LT for my daughter last week. Maybe we can hook up to figure it out.
