Message Gate ajar
While in motion, the light "gate ajar" has started coming on occasionally. The liftgate is closed, naturally. Where should I look for the problem in the first place?
Loose wires inside the gate at the latch mechanism |
Thank you. But I do not quite understand where? Is number 1 or 2?https://cimg0.ibsrv.net/gimg/www.che...18415c0c78.png
Check switch #1 pin#6 pink and black wire. Might be a wire issue or possibly the switch is bad
It looks like you will have to remove the liftgate panel to get to it. https://cimg6.ibsrv.net/gimg/www.che...c20bea56e2.png |
#1 latch
#2 touchpad |
Why
Why can a door or a gate be "ajar", BUT a jar can not be a door or gate?
Go figure. I was asked that by a 5 year old nephew..... |
A moment to ponder! |
What do you think, if I cut the wire from BSM # 55, the signal disappears?https://cimg6.ibsrv.net/gimg/www.che...d4ac056ff6.png
If it is damaged inside the harness, does the signal appear? |
If you ground that wire the message should go away The "closed " signal needs to be present for the Remote Start to work.
