Misfire / traction control light???
Old Aug 23, 2019 | 02:19 PM
Only 2 ways for oil to foul plugs. Valve seals or rings.
Old Aug 23, 2019 | 04:05 PM
3 hole in the piston dome , usually from a timing chain failure.
Old Aug 23, 2019 | 04:28 PM
Bkspring's Avatar
So I have 145lbs of compression in 1.3.4 and 0 in 2.
Took a inspection camera looked into the combustion chamber and no hole in piston. Going to pull valve cover to see if I have a stuck lifter . Timing chain has not broken or failed.
Old Aug 23, 2019 | 04:36 PM
But that front guide?
Old Aug 23, 2019 | 05:00 PM
Bkspring's Avatar
What frount guide
Old Aug 23, 2019 | 05:05 PM
Was the piston coated in oil ? As Don stated, there's only a couple ways for oil to get into the cylinder. A "stuck lifter" wouldn't be one of those ways.
Still believe you have a major failure in there.
I remember a while back a member here scoped his, didn't see any piston damage, then tore it down and found the edge of the piston broken off.
Old Aug 23, 2019 | 05:58 PM
Guide information
https://www.google.ca/search?q=ecote...&client=safari
Old Aug 23, 2019 | 06:38 PM
Do these engines even have lifters?
No compression + oil, usually indicates rings or piston damage.
Old Aug 23, 2019 | 11:35 PM
Overhead cam kind of negates lifters.
Old Aug 24, 2019 | 07:07 AM
More like a place for the cam to roll and push down on that rocker arm and force the valves open as the lobe rolls around
https://zzperformance.com/products/rocker-arms
