MORE abs/traction problems
I've changed all wheel hubs checked continuity of wire harness all is good but still lights are on, I took the old hubs checked continuity between terminals as soon as I spin even just slowly it shows continuity between them all old ones did so that was a reference point so I thought went back to new wheel hubs and got absolutely nothing is this telling me new hubs are no good? The codes I'm getting is C0045 & C0055 left and right rear circuits bad any ideas what to check next????? Thanks Also my brake light came on after new hubs installed
https://cimg3.ibsrv.net/gimg/www.che...5c1046e40.jpeg
check continuity in the rear ABS harness |
Please start from the beginning. I moved your post from a dead thread from 2015.
Why did you change hubs, etc. |
X2
And please include the year, model, mileage etc. Also as Donbrew stated, why change the hubs ? Maybe include a little of the car's history. |
It's a 2009 with 340000 Klms felt it would fix my problem with changing hubs with that many klms on it well it didn't but did find a broken wire in rear harness the red one fixed that with new hubs it still had the codes I put old hubs back on problem solved no more lights
Must be the connectors.
