MORE abs/traction problems
Old Oct 10, 2020 | 01:18 PM
miktel53's Avatar
I've changed all wheel hubs checked continuity of wire harness all is good but still lights are on, I took the old hubs checked continuity between terminals as soon as I spin even just slowly it shows continuity between them all old ones did so that was a reference point so I thought went back to new wheel hubs and got absolutely nothing is this telling me new hubs are no good? The codes I'm getting is C0045 & C0055 left and right rear circuits bad any ideas what to check next????? Thanks Also my brake light came on after new hubs installed
Old Oct 10, 2020 | 02:18 PM
check continuity in the rear ABS harness
Old Oct 10, 2020 | 04:44 PM
Please start from the beginning. I moved your post from a dead thread from 2015.
Why did you change hubs, etc.
Old Oct 10, 2020 | 05:07 PM
X2
And please include the year, model, mileage etc. Also as Donbrew stated, why change the hubs ? Maybe include a little of the car's history.
Old Oct 14, 2020 | 07:29 PM
miktel53's Avatar
It's a 2009 with 340000 Klms felt it would fix my problem with changing hubs with that many klms on it well it didn't but did find a broken wire in rear harness the red one fixed that with new hubs it still had the codes I put old hubs back on problem solved no more lights
Old Oct 14, 2020 | 08:17 PM
Must be the connectors.
MikeFree01
7
May 16, 2020 09:04 AM
ald
Jun 2, 2016 12:17 AM
MJC3131
12
Apr 11, 2016 11:10 AM
mcgrosjr
Drivetrain (Excluding Engine)
Apr 24, 2013 11:44 AM
