Chevy HHR Network
-   -   motor mounts (https://www.chevyhhr.net/forums/problems-service-repairs-42/motor-mounts-35198/)
2011hhr2011 Apr 21, 2011 06:13 PM
motor mounts
2011 HHR - less than 5000 miles. 3 times after coming to a stop I felt intense vibrations coming thru the steering wheel. I opened the hood and the engine was vibrating furiously. Took to dealer - they could not find anything. About a week ago I noticed some kind of lubricant under the car. I took to dealer - said it was a bad seal where transaxle cooler pipes connect to the transmission. I asked if the engine vibrations could have caused this - they said no. After I got the work order, I noticed they replaced the transaxle cooler pipes. I believe the vibrations caused this problem. The next time this happens I will place a container of liquid on top of the engine and video the effects of these furious vibrations. I will also use it to prepare a case if I am forced to resort to a LemonLaw case. I believe it's a faulty motor mount - I will want them to replace all 4 mounts as the damage caused by these furious vibrations will surely be causing collateral damage.
gcsd3742 Apr 21, 2011 06:21 PM
there's thread on here about motor/trans. mounts but i hear ya....G/L Maybe just do like others bite the bullet and just fix it yourself...the motor mounts and trans. mounts I had them off and new replaced in like 1 1/2 hours and stopped for a sandwich....
kornellred Apr 22, 2011 09:33 PM
You have furious engine vibration and there is no check engine light or warnings showing in the DIC? That is truly hard to believe....
2011hhr2011 Oct 23, 2011 07:48 AM
believe it - that's what happened.
843de Oct 23, 2011 08:08 AM
Take it to another dealer and make sure you contact Michelle at Chevrolet, you can send her a PM by using her user name ChevroletCustomerService.
prod Oct 23, 2011 10:31 AM
Yeah with vibration like you are describing, I would suspect a misfiring cylinder.
ATLsilverSS Oct 23, 2011 12:35 PM
contrary to popular belief things can go wrong with these cars without throwing a code
RBradley Oct 23, 2011 02:01 PM
"You have furious engine vibration and there is no check engine light or warnings showing in the DIC? That is truly hard to believe.... "
That's a pretty ridiculous comment.
Doc brown Oct 24, 2011 09:26 AM
This is true with any car.
ChevroletCustomerService Oct 24, 2011 03:52 PM
@843de, thank you!!!!!!
How is your Monday going?
