murply416
Old Sep 28, 2014 | 09:02 AM
murply416's Avatar
murply416
side view mirrors do not adjust. When I fixed the door handle and replaced the door panel , it did not work.
what did i do wrong?
Old Sep 28, 2014 | 10:36 AM
db/sb's Avatar
If it worked before you replaced the door handle/panel then you either didn't re connect the mirror, blew the fuse, or somehow damaged the switch. If neither side works, you blew the fuse.
Old Sep 28, 2014 | 10:57 AM
Welcome to the site, check the fuses then if required remove the door panel and check the connections
Old Sep 28, 2014 | 11:05 AM
Could have broken a wire.
