My heater/AC fan wont shut off
My fan control has four click positions but only two speeds. The first three positions are low and the last position is high. It wont turn off completely. Has anyone else encountered this? I am taking it to the dealership next week to see whats up.
No, sounds like you`re headed in the right direction though, the Dealer.
Sounds like a wiring thing, maybe? Definitely see the dealership about it.
I had a similar problem last fall. I could not turn the fan off or it would turn on by itself. The dealer found a fried resistor and replaced, but after I picked it up and took it home I found that it still did it. I took it back in and they could not find anything else wrong. They attributed it to the afterblow feature possibly being turned on, which I found given the use and outside temp that it could not have been that. I was going to take it back in, but then it quit doing it and has worked fine since.
The afterblow feature?
Originally Posted by nss79
(Post 160184)
and now back to our regularly scheduled thread............. |
Originally Posted by Black Beauty
(Post 160187)
Well I`ve been driving with the a/c on lately, when I pull in the garage, it`s pretty quiet, if there`s some sort of fan blowing, after I turn the ride off, it`s mighty quiet.
The afterblow feature comes from the factory off, so unless you had it turned on your car won't do it. I was told it may have been activated when they worked on it the first time--then I found out how the feature actually worked.
(Post 160318)
