My leaky HHR saga: Back to coolant
Old Jun 15, 2007 | 09:46 AM
Lone Ranger's Avatar
Agreed.
Originally Posted by hhrcrafty
Gaskets get torn, surfaces get marred, it's called an assembly line. Sometimes you just gotta get stuff like this done. It doesn't mean that all of the 200,000 odd HHR's out there are going to have this problem, just one guy who's posted it on the internet so far.
Old Jun 15, 2007 | 01:27 PM
GCarp's Avatar
Do they still use gaskets? I thought they were using that stuff that looks like caulk nowadays.
Old Jun 15, 2007 | 01:42 PM
Snoopy's Avatar
In some instances.
Look real well at picture 2, post 1 of "It's raining transmission fluid....". You probably will notice the black "neoprene" gasket. Also, as some have mentioned....the "gasket" is probably reuseable when removing the valve cover.
Old Jun 15, 2007 | 02:00 PM
Desert Coyote's Avatar
Originally Posted by Lone Ranger
Check it out. I was able to look it up, except for being for a 2005 Cobalt, BUT it is the 2.2L L61 engine-- should be same part:
NOTE: If this is the part he was referring to. Ought to be, though.
That's not an HHR 2.2. The designation is wrong (HHR's engine designation is L850. L61 is a Spring Hill engine). I wouldn't doubt, however, that the two would probably use the same water neck.
Old Jun 15, 2007 | 03:04 PM
Black Rose's Avatar
The GM Canada HHR site lists the available engines as L61 (2.2) and LE5 (2.4)
So does the GM Powertrain site:
http://media.gm.com/us/powertrain/en...07/07truck.htm
Old Jun 15, 2007 | 07:08 PM
  #26
nfboy's Avatar
Thank-you. Dead on.
Old Jun 15, 2007 | 07:42 PM
  #27
Black Beauty's Avatar
Hey, what do you mean, "Just one Guy", You`re talking about The Lone Ranger, hi-ho Silver away, that Guy
Old Jun 15, 2007 | 10:24 PM
  #28
Thumbs up Back from the dealer today
I picked the HHR up after work today. They showed me the part, but said it has to go to GM. I didn't get a photo, but its the part in the schematic I posted. It was leaking where one of the metal tubes that a 1 inch (?) diameter coolant line connects to, leaking at the base of this tube where it was mated to the forged aluminum body of the housing.
Heard a gurgeling percolating sound in the passenger side of dash right after starting it up at the dealer to go home, most likely the heater core. Probably some air in the system from the re-fill they would have had to do. Hasn't done it again so must have burped itself out.
Here he is hanging out with his roommate tonight:
Old Jun 16, 2007 | 02:50 AM
  #29
Goose's Avatar
Tonto
Old Jun 16, 2007 | 07:59 PM
  #30
I knew that piece was a leak waiting to happen.
So is that the same part for both motors, do you know, or were you just happy to get out of the dealer?
