Need help
Need help
For some odd reason I can't seem to find what type of bulb goes in the stock foglights. H10, H11, 9140, 9145 then when you go to dbl check, no match.
What the heck goes in this dang car, and why are the parts places so retarded.
I don't have any help to offer, but I did just go out and check the manual for my 2006. It does not have a listing for the fog lamp bulb. There is a footnote on the page saying to contact the dealer for any lamps not listed.
Yeah I know. One parts place i went to, my Mazda MPV had a bad starter ( screeching sound and sparks visible between nose section and motor casing). The kid (20 yrs maybe) insisted on hooking up the "starter tester" to my battery. Well sure enough, it tested "good". I asked the kid did you not hear that? He looked me right in the eye and said "The tester says its good so there is nothing wrong with your starter.".....I wanted to smack the kid. Finally I said , just order the damn starter and shut up. 2 days later I had a new starter and all is fine.
Have you pulled the bulb that is out to check the number that is on it? I believe in an earlier post oneton verified that you need a 9145, if you are reluctant to beleive him I would contact your local chevy dealer.
