New Battery -now issues
Today my car battery died Replaced it but now the radio, door locks and the noise on the blinkers do not work? At a loss, what do I need to fix now? Thank you for any tips!
2007 HHR LS
2007 HHR LS
When you replaced the battery did you bother the plastic thing the encircles the negative cable or knock the maxi-fuse next to the ground cleat?
That fuse is [power for the BCM that controls the things that stopped working.
TOUCHING THE CABLE ENDS TOGETHER FOR 30 SECONDS.
When the cable ends touched while I was replacing a battery, there was a spark and the RAP discharged, killing the radio. It is my experience that a battery lobotomy should be at least 15 to 30 minutes. This resets the computers back to OEM settings
