New code in my 2009 money pit
Old Oct 4, 2021 | 08:57 AM
my6thchevy's Avatar
Wondering what to look for . Code is p0171 (system too lean bank 1). Car starts & seems to run fine. Dealer that I purchased from last Dec. said "injectors" replaced. Has new air filter. DUH?
Old Oct 4, 2021 | 09:02 AM
Usually it’s a simple fix, plug in the MAF sensor, firmly. Start there.
https://www.autoblog.com/2016/04/06/...o-lean-bank-1/
Also listen by the flex pipe for leaks before the O2 sensor.
Old Oct 4, 2021 | 10:34 AM
Actually it is "FUEL TRIM system lean". That is the opposite of what you think it means.
Old Oct 4, 2021 | 10:53 AM
https://www.chevyhhr.net/forums/prob...control-64366/
Could be
Old Oct 4, 2021 | 11:03 AM
my6thchevy's Avatar
Thanks!!!
Old Oct 4, 2021 | 01:38 PM
PulpFriction's Avatar
I had sort of the opposite, P0172. It was starting WAY too rich, smoke and all, and the fuel “trim” would only correct after it got warm enough for the O2 sensors to work. Turned out the system was convinced it had 50% ethanol in the tank, even though a sample tested 11%. It should have know better, eventually, anyway. I ended up taking it to the dealer to reset the ethanol % to zero, because my scanner wouldn’t do it, nor my regular mechanic’s. After a few weeks, the car set itself to 10% ethanol, consistent with what I had been pumping.
May have been triggered by a fuel line leak and /or short trips, saying that only because another member here had a nearly identical experience after short trips and a fuel line leak. It was his thread that clued me in to check the ethanol % in the computer and in the tank.
P0171 Fuel Trim System Lean
P0172 Fuel Trim System Rich
Do you ever use E85 fuel? Or maybe accidentally, or been at a station that sells it and maybe mixed things up? Not the it should cause this problem, because 2009 and later are supposed to be fine with E85.
The air/fuel mix with E85 needs to be very different that with gasoline (which is often E10, of course.)
Obviously your problem is quite different than mine was, but after trying the other easier things, I might suggest sampling the fuel for ethanol %, and with the right scanner you can check what the computer thinks the ethanol % is, and also monitor the long and short-term fuel trim as the car warms up.
Also, it turns out that with FlexFuel, it’s especially important to turn off the motor when fueling. Donbrew has a pretty good explanation for that.
Old Oct 4, 2021 | 05:42 PM
my6thchevy's Avatar
Thanks! Wanted to see what is being said before she goes to the "hospital" (shop) on Wednesday. Printing responses to give to mechanic. Thanks again!
Old Oct 4, 2021 | 06:04 PM
You can check the MAF sensor connector, yourself
cturboaddict
Jan 29, 2026 07:49 PM
gag
Apr 12, 2024 07:13 AM
kewatin
Sep 14, 2015 05:15 PM
andyb
2.0L Performance Tech
May 23, 2013 10:19 AM
oneokie1
Feb 15, 2012 09:29 PM
