new owner of 2006
my car all of a sudden wont start, one day before it happen, i went to start it and it sounded like the battery was dragging but it did start, next day nothing. all it does is click, so i put the battery charger on it and still wont, im lost t what to do now. do i go buy new one or what. ? please please help.
Hi Jackie,
to the forums!
Have the ignition related recalls been performed? Link to check your recall status is in my signature.
Auto Parts stores will perform a free battery load test, be prepared to leave the battery with them for charging before they can test it.
to the forums!Have the ignition related recalls been performed? Link to check your recall status is in my signature.
If you’re the new owner, safe bet you have an expired or dead battery. Considering your new to the HHR, the battery is in the back down with the spare tire.
remove the negative cable first, wrap it in a dry towel or a nitrile glove , then remove the positive cable and wrap it or put a nitrile glove. You do not want them touching together. The nuts are 10 mm the clamp bolt is either a 13 or 14 mm gently remove the vent tube from the battery then lift the battery out . It’s a series 90 650 CCA battery
sail414
May 25, 2009 10:06 AM
