Won't start...
Old Aug 7, 2012 | 08:48 AM
roofer1976's Avatar
Won't start...
Ran fine all day yesterday. Went to start this morning, and it won't start. Tried jumping with a plug in unit, but no luck. When I turn the key, there is no crank, dash lights up, can turn the radio on.
Any ideas?
Old Aug 7, 2012 | 08:54 AM
solman98's Avatar
Hard to say. Check cable connections. If the battery is really run down, it might need a little charge before it will jump.
CHeck fuses.
Old Aug 7, 2012 | 09:15 AM
First. Check the battery with a voltage meter and see how much it has.
12.7-12.8 range would be OK.
If the battery is charged, well it could be a bunch of other possibles.
Old Aug 7, 2012 | 09:20 AM
roofer1976's Avatar
Thanks for the response. After charging the plug in unit for an hour, decided to try again, still no luck. While sitting there, defeated, I feel the urge to take it out of park, then put it back. The car starts right up! Maybe the shifter wasn't sitting just rigjt?
Old Aug 7, 2012 | 09:55 AM
Funny, but that was my initial thought about the shifter safety switch. It may be on the "way out" so to speak. You might want to have to checked out and line up a replacement part just in case.
roofer1976
Jan 4, 2014 02:09 PM
spidermanshhr
Jan 7, 2013 09:47 PM
1900colt
Oct 29, 2012 12:01 PM
7734
May 28, 2010 01:12 PM
HillsdaleHHR
Feb 21, 2009 02:26 PM
