P0236 and no fix
Old May 24, 2012 | 03:16 PM
Angry P0236 and no fix
Several weekends ago coming home from Coldwater the car started acting up. It wouldn't boost above 5 psi and while traveling a steady speed felt as if the car was surging ever so slightly off and on. No warning lights occured. Sunday, Monday, and Tuesday morning the car drove fine. Tuesday afternoon the Check Engine Light came on so dropped the car off at the dealership. That was on the 8th. They've had the car ever since.
I have not been personally dealing with them (Chris has) but they have said they have replaced everything that they can think of and that they are going to escalate it to a Tier 2. I just want my car back.
Old May 24, 2012 | 03:32 PM
ChevyMgr's Avatar
What have they replaced?
Old May 24, 2012 | 03:55 PM
Tyler Harvey's Avatar
Turbocharger Boost System Performance. Weird, could be a few things.
Old May 24, 2012 | 04:59 PM
09 Silver Bullett's Avatar
Maybe the stage 1 wiring? Map sensors?
Good luck with it.
Lets us know what they find.
Old May 24, 2012 | 05:09 PM
Well again, I'm not the one that has been dealing with them but Chris mentioned the ECM, the air flow sensor, something about an actuator, the wiring harness, and the tune itself. Now they are thinking it's the turbo itself.
Old May 24, 2012 | 08:32 PM
Sounds like they're shooting in the dark on this deal, is there another dealer or GM tech nearby to take it to for a second opinion and diagnostic checks?
Old May 26, 2012 | 09:46 AM
tsalva's Avatar
Code 0236 fix
Hello
I had a very similar problem with my 09 HHR SS w/ GM LNF updgrade. Had intermittent boost up to max 5 psi or no boost at all for days. Then several days later the Check Engine light came on. Took to dealer and it was diagnosed with code P0236 and J6370. They replaced the LNF special MAP sensor in the cooler discharge. Workorder lists 2 sensors replaced: PN 12592017 & 55206797.
Good Luck
Thomas
Old May 26, 2012 | 09:49 AM
to the forum Thomas, and thanks for the info!
When you get a chance, shoot on over to "Introductions" and tell us a bit about yourself and your SS.
Old May 26, 2012 | 03:01 PM
I can understand wanting your vehicle back. I would like to do some research on my end, could you provide me with the case number?
Old May 27, 2012 | 03:46 PM
Originally Posted by tsalva
Hello
Good Luck
Thomas
Welcome!!! Thank you for sharing your experience with this. I hope this concern will remain gone so you can enjoy many Summer evenings in your HHR. Please, don't hesitate to contact me in the future with comments, questions and/or concerns.
