New Problem.
Alright, so I popped my wooly worm back on, and got a P0171 code shortly after. Researched it, and someone else on here, I believe DonBrew had his Catalytic Converter fracture end to end on him, not along the seam, and that's what his problem was. I still hear the sound with the work attached, and it is only on pedal acceleration that I hear it. If I slow down, and down shift, and the motor revs, the sound is not there.
My problem was the flex joint broke (twice) , giving whatever the code it was for HO2 sensor problems. That is a result of the #1 and #2 sensors not giving the correct difference, outside air inducting into the before cat throws the readings off.
P0171 seems to be related to the MAF sensor or a vacuum leak. Also your "wooly worm" might have a hole in it.
Wooly worm was off the box until today when I decided to put it back on to see if it would make any difference. Other than giving me the P0171 code, it didn't change much. I imagine that I got that code going from engine bay air, to worm air from the right wheel well..
