New Problem.
Old Apr 4, 2013 | 01:27 PM
  #61
LawDog88's Avatar
So, if I get the parts from say AZ does it come with a pressure plate? I can't find any info on it.
Old Apr 4, 2013 | 04:52 PM
  #62
You should be able to get a complete clutch set. Disc,pressure plate, slave cylinder, and bearing. That's probably the best way to go for you.
Since you have to pull the tranny,replace all the components with new ones
while you're in there.
( I took a quick look at Advance Auto online and saw a set for about $300)
Old Apr 4, 2013 | 05:32 PM
  #63
LawDog88's Avatar
I can get one from AZ for $100 less than the Advanced Auto one FMG. ;-) Cousin is Store Manager of one. Got the hook-up.
Old Apr 4, 2013 | 11:26 PM
  #64
Kev- Make sure the kit is complete..
Clutch disc, pressure plate, slave cylinder, and throw out bearing.
Also a pilot bearing.
EDIT: If you can get all that for $100. less.. That's some deal then.
Don't forget the flywheel will need to be re-surfaced by a machine shop.
& before flywheel removal, I would mark it's orientation, so it can be put back on in same position, they are balanced.
Old Apr 4, 2013 | 11:45 PM
  #65
that sounds like a deal (sleeper - it's a $100 LESS than advanced Auto - I'll loan you my reading glasses till I misread something - which will probably be about 10 mins from now - )
Old Apr 4, 2013 | 11:53 PM
  #66
Doh !!! Yep I guess I do need to borrow your readers..
Mine are just sitting here on the desk, in their case..
Thanks Whopper !!!
Old Apr 5, 2013 | 09:57 AM
  #67
LawDog88's Avatar
Do I sense Sarcasm coming from a Mod? It's a complete kit afaik. See link.
http://goo.gl/h0dyf
Old Apr 5, 2013 | 11:10 AM
  #68
Thanks Whopper !!!
Anytime bud!!!!
Old Apr 5, 2013 | 11:12 AM
  #69
http://goo.gl/h0dyf
Looks good guy. AZ is a favorite of mine - I've been ordering a lot of stuff from them the last while.
Old Apr 6, 2013 | 12:12 AM
  #70
Anytime bud!!!!
Danke, Freund .
