Nicked Pistons from jumped timing chain
Old Mar 27, 2015 | 05:20 PM
  #31
I have a Victor Reinz head gasket that might fit, I bought it for a 2008 2.2L. P/N 54440
PM if you would like it cheap.
The eBay description says it is Multi Layer Steel and it fits a 2006 2.2L. Mine is still shrink wrapped to the cardboard, so I cannot vouch for it. Color is Dark Gray-Blue , if it was wet probably black.
Old Mar 30, 2015 | 05:59 PM
  #32
Jcdew67's Avatar
I have a Fel Pro MLS Permatorque already but ty for the offer.
Old Apr 15, 2015 | 04:10 PM
  #33
Jcdew67's Avatar
Got a new Cylinder Head and in the process of putting it on but had to stop because it has been raining and will rain for the next week.
I lightly coated the head bolt threads and the underside of the bolts heads with oil and torqued em down then angle gauged them,this is where I stopped until it stops raining someday.lol
I was really surprised that it called for only 22 ft pnds then 155 degrees but I assume since things are aluminum that explains it.
Old Apr 15, 2015 | 05:25 PM
  #34
Stretch bolts, you used new ones?
Old Apr 15, 2015 | 06:11 PM
  #35
Jcdew67's Avatar
Yes I did,I managed to find brand new ones for $35
Old Apr 17, 2015 | 08:14 PM
  #36
Jcdew67's Avatar
Got everything hooked up and car running. So far so good,runs perfect. I let the car heat up until the fan kicked on and then off. I have done this a few times today.
I will drive it some more tomorrow while I have my Autoenginuity laptop on it.
I will come back after a week and let you know how it is going.
Old Apr 19, 2015 | 12:59 PM
  #37
Jcdew67's Avatar
I'm back so soon.
Hooked Scanner/Code Reader up and everything was working as per specs.
Engine vacuum was a steady 20.
Saw no fluid leaks.
I put about 400 miles on it doing city and Highway miles.
Just changed the oil and filter with Mobil 1 5w-30 full synthetic and oil filter,not a bit of noise or codes.
Thanks everyone for your help =)
Old Apr 19, 2015 | 03:14 PM
  #38
Good to hear that it's working fine. Saved the kids some money I bet.
Old Apr 19, 2015 | 05:27 PM
  #39
Great news!!
Old Jun 12, 2015 | 12:02 PM
  #40
Jcdew67's Avatar
Just coming back to say HHR is still running great,he has put a lot of miles on it since I repaired it.
Only thing that made me curious is he said he had a ticking noise on his engine for a day or two and it threw a knock sensor code but the ticking went away after and hasn't come back.
Everything looked and was showing fine,I reset the code and it hasn't come back so far.
I told him to just make sure his oil and fluids are fine and his engine isn't overheating.
