No AC, temperature reading, and temp. gauge
Old Jun 10, 2015 | 05:09 PM
GibsonHHR's Avatar
I have a 2008 LT2 with 170,000 miles. I have an intermittent problem. My temperature gauge won't work, coolant reads---,and no AC. The next day everything works fine. This has happened 4 times in the past six weeks. Any thoughts?
Old Jun 10, 2015 | 05:16 PM
black Tara's Avatar
Welcome to the most biggest and friendly, helpful HHR forum on the net.
Could be a loose fuse? Check it make sure they are all snug as a bug :)
Tim
Old Jun 10, 2015 | 05:19 PM
oldracer's Avatar
I had this happen and I replaced both the thermostat and the sender since they are in the same area and either one can cause problems. I figured why not since they are pretty cheap and not having A/C is a pain!
Old Jun 10, 2015 | 05:31 PM
GibsonHHR's Avatar
Tim
Thanks, I'll try them all.
Old Jun 10, 2015 | 05:34 PM
GibsonHHR's Avatar
[QUOTE=oldracer;781653]I had this happen and I replaced both the thermostat and the sender since they are in the same area and either one can cause problems. I figured why not since they are pretty cheap and not having A/C is a pain![/QUOTE
Thank you. I'll check into that.
Old Jun 10, 2015 | 05:51 PM
Thermostat - well known issue. Sometimes it will light up the CEL with a P0128 code , but not always.
Old Jun 10, 2015 | 06:26 PM
Hey GibsonHHR,
Welcome to the forum! Looks like you've received some great advice already, but let us know in a PM if you'd like to have your HHR taken to a dealership. I can have your preferred one reach out to you for a diagnosis.
Let us know if that's something you'd like us to do. We're here to assist. Also, send us a PM when your HHR hits 200,000 miles!
Regards,
Geoff G.
Chevrolet Customer Care
Old Jun 10, 2015 | 07:00 PM
LawDog88's Avatar
T-stat. Had it happen many times.
Old Jun 10, 2015 | 10:41 PM
Tutorial by Smoke Wagon on changing the thermostat and saving yourself a few $'s - https://www.chevyhhr.net/forums/how-...l-p0128-24493/
Old Jun 11, 2015 | 06:09 AM
08LaRam's Avatar
Thermostat, had the exact same problem. Luckily mine was under warranty so no $350.00 bill to go along with the fix.
