No Cold Overdrive
Old Apr 9, 2013 | 06:35 AM
rocdoc2112's Avatar
Angry No Cold Overdrive
I have a 2009 with a 2.2. When the vehicle is cold the car does not shift into overdrive. The vehicle has about 45000 miles on it. When I took it into the dealer it cost me 100.00 for them to say what its doing is normal. So I took it to another dealer, I explained to the service advisor "while the vehicle is cold it does not shift into overdrive, but after it warms up it does, so depending on the temps outside will determine how long it takes to shift into overdrive. Once it shift into overdrive there are no problems. No codes ever come up, but the problem is still there. I NEED HELP.
Old Apr 9, 2013 | 06:38 AM
db/sb's Avatar
Welcome to the site. Our 2006 did that also....for the entire 7+ years we owned it. It's normal.
Old Apr 9, 2013 | 06:46 AM
rocdoc2112's Avatar
If its normal why did it not happen util now? I have done soe research and not sure if TCM or Torque converter lockup.
Old Apr 9, 2013 | 06:49 AM
jaymz's Avatar
Replace your thermostat.
Jim
Old Apr 9, 2013 | 06:51 AM
rocdoc2112's Avatar
what does thathave to do with the trans? or better yet the temps outside?
Old Apr 9, 2013 | 06:57 AM
jaymz's Avatar
Slow opening thermostat delays "warm up cycles" in computer. Happened in my Ford Lightning. If TS is easy to replace, it couldn't hurt.
Jim
Old Apr 9, 2013 | 08:11 AM
db/sb's Avatar
You probably didn't notice it until the colder weather. There is the possibility that you have a slow opening thermostat as mentioned which would make the process take longer than it should but it's still doesn't go into overdrive until a certain temperature even with a good thermostat. But I'm not sure that really has anything to do with it. In the trans schematic, there is a fluid temp sensor. I'm thinking that where the temperature dependant overdrive signal comes from. I was trying to think of an explaination but this one from ASE Study Guides explains it:
Transmission Fluid Temperature Sensor
A TFT sensor or transmission fluid temperature sensor is one of many sensors utilized by the transmission control module. It is the located in the valve body or oil pan of the transmission or transaxle. The TCM uses this sensor to monitor the temperature of the transmission fluid.
Thermistor's like the TFT alter resistance as temperature changes. We know with ohms law that as resistance changes the voltage signal changes as well. By increasing resistance we lower the voltage signal to the TCM. Most transmission fluid temperature sensors are NTC or negative temperature coefficient. This means that resistance decreases as the temperature increases. The opposite is true for a positive temperature coefficient sensor.
With these sensors the resistance increases as the temperature increases. Both of these temperature sensors use varying resistance to control the signal voltage to the TCM. They are similar to an ECT or engine coolant temperature sensor that monitors coolant temperature for the PCM.
The TCM uses this input along with other sensors to control the transmissions operations. When the temperature is cold the TCM will delay torque converter clutch or TCC operation until the fluid reaches a certain temperature. The TCM will engage the TCC mechanically connecting the input shaft to the engine in an attempt to cool the fluid if it gets too hot. If the temperature reaches a threshold set by the manufacturer: 300° F or so, the TCM will set a code and illuminate the MIL to inform the driver. A faulty TFT sensor will affect the torque converter and the transmissions line pressure.
The sensors output can monitored with a scan tool and the results compared to the actual temperature. You can use a temperature probe attached to a DMM and then lowered down the dipstick tube. A DMM is also used to measure the resistance of the sensor. The sensors resistance can be checked at room temperature, cooled, or warmed in hot water and checked against manufactures specifications. The fault may be in the sensor, the sensors circuit, or the TCM.
Old Apr 9, 2013 | 12:03 PM
IgottaWoody's Avatar
The Overdrive/ TC lockup does not occur until you hit around 155 deg..this is normal..when its cold out it takes longer, its so you dont lug down the eng until its warmed up. Ive watched this several times to determine when it happens, so yours may be different as probably no two are the same. I also watched the temp rise during different outside temps and it doesnt like the cold, takes way longer to warm up while driving. this is the main reason fuel milage drops so bad in the winter time, takes much longer and car runs in cold mode( same as a choke on carb motors).
Old Apr 10, 2013 | 12:47 PM
rocdoc2112's Avatar
how do i load a photo here of my car?
Old Apr 10, 2013 | 12:51 PM
rocdoc2112's Avatar
I made a video on sat of my issue, I noticed on the video the outside temp was like about 50 degrees outside and it took almost 6 miles for the torque converter lockup to engage. After 4 years this is my first year having this issue.
