No crank no start.
Old Apr 10, 2024 | 02:08 PM
hunter0128's Avatar
No crank no start.
Hello all the dreaded no crank no start
-fuses are good
-recall has been done (2014)
-battery is good and getting power to the fuse box
-security light is not on
- starter solenoid is functioning
​​​​​​- fuel pump is functioning
-no check engine light
background info. Car has been sitting for well over 2 years waiting on a trans. I wasn’t here when it first broke. Trans has been replaced now and I’ve got it back together as it was taken apart. I get dash lights and hear relays click. I can apply direct power to the starter solenoid and it’ll turn over but no fuel pump. If I jump over the fuel pump relay it’ll work.
it’s acting like it’s in a security shut out. However I haven’t got a security light. Also wipers don’t work as well as headlights.No check engine light I won’t have my scan tool till tomorrow about noon. So I can’t see any codes.
any help is appreciated thanks
Old Apr 10, 2024 | 02:39 PM
Year, model and engine ?
Your bio says 2012 HHR. HHR’s were 2006-2011.
Old Apr 10, 2024 | 03:00 PM
Double check the under hood fuse box are those 4 bolts cranked down good and tight?
Old Apr 10, 2024 | 09:26 PM
greg8453's Avatar
How do you know the fuses and battery are good. Have you put a meter on anything? If the starter solenoid is good wouldn't it be cranking?
Start at the battery. What will it load test at?
Old Apr 11, 2024 | 03:06 PM
hunter0128's Avatar
sorry 09 hhr with the 2.2l
Old Apr 11, 2024 | 03:08 PM
hunter0128's Avatar
battery is brand new. Also on a jump pack to keep it in tip top shape while testing. fuses have been tested with a test light and multimeter.
Old Apr 11, 2024 | 03:12 PM
hunter0128's Avatar
just triple checked. No change but now i have a check engine light
Old Apr 11, 2024 | 04:58 PM
And the code is? Just code please.
Old Apr 11, 2024 | 05:42 PM
greg8453's Avatar
Ignition switch? What's going on at the relay? We need numbers not tests OK
Old Apr 11, 2024 | 07:10 PM
Ignition recall done in 2014, as posting in #1.
Im thinking a ground wire is loose or corroded.
as a side thought why not try a battery lobotomy for 15 minutes. It’s worked before.
