no dash lights?
no dash lights?
I searched before posting, so I apologize if this has been discussed before.
Got in the car last night and something seemed strange. I finally realized that most of my dash lights weren't working! I had my gauges and all the radio lights, but no overhead blue light and no lights on the temp controls, steering wheel buttons, shifter, door lock buttons, or window buttons.
I pulled every single fuse today to make sure they were seated and functioning. Everything was fine. I'm thinking maybe a connector has come loose somewhere, but I'm a girl and I have no clue about that kind of stuff. Any ideas? I've driven out my warranty so I'd really like to avoid going to the dealer if I can.
It has been discussed here before, potential problems with Dash Lights, not real sure the outcome or if a definite fix was identified.
My dash lights, do change, intermitely, bright/low/on/off, but never has stuck just off.
Below is link to another discussion of issues with Dash lights, that may help:
https://www.chevyhhr.net/forums/audio-video-17/dimmer-switch-5358/
Later,
Markiemark
Later,
Markiemark
Issue I had on 11/1/06, after messing with the the electrical system:
I had a similar problem last night. I noticed no lights on steering wheel, HVAC, or the roof LED. Unfortunately, the tail lights and front parking lights were out too. Turns out I blew the parking light fuse (pleading the 5th on how ). It is fuse #69 (10 amp) under the hood. Once I replaced it all was well.
Just throwing it out there...
Edit- OOPS - I just pulled my old post from the thread that Markiemark referenced above...didn't realize it was the same one.
