No Power From Cigarette Lighter
Old Jan 22, 2017 | 12:22 AM
HWD510's Avatar
Unhappy No Power From Cigarette Lighter
The other day while removing my cell phone car charger from the cigarette lighter, the charger broke and came apart. I bought a new charger and noticed it was not drawing power. I tested the charger on the other cigarette lighter in the back and it works. So I am assuming that somehow the cigarette lighter receptacle got damaged. I intend to replace the receptacle. While researching which part to buy, I'm getting 2 different part numbers. I have a 2006 HHR LT2. What is the correct part number? Where can I find the correct info? Some sites point me to one direction and one to another. Is there something else I should look into before proceeding to replace the receptacle? Any help is greatly appreciated.
Old Jan 22, 2017 | 02:42 AM
Did you check the fuse? Ie: fuse 29, in the fuse box in the engine compartment.
When you mention possible parts that you were looking at, would it not be a good idea to post a link to them?
Old Jan 22, 2017 | 05:46 AM
You most likely came up with 2 different part numbers because there were 2 different sockets offered.
One was the cigarette lighter socket which came with the Smokers Package option.
The second would just be a power outlet socket that would have the rubber cap on the socket.
The one "in the back" is not a cigarette lighter. It is an aux.power outlet
Old Jan 22, 2017 | 07:50 AM
Here is the GM part, I have a spare used one in my parts stash
OEM 25774623 Auxiliary Accessory Power Outlet Receptacle for GM New | eBay
Old Jan 22, 2017 | 08:05 AM
They are on separate fuses.
When the charger broke it probably shorted and blew the fuse.
Old Jan 22, 2017 | 05:44 PM
HWD510's Avatar
You guys rock! Thank you, I will check the fuses once it stops raining here in Northern California.
Old Jan 22, 2017 | 07:38 PM
That one shows up as the one in the floor console.
RECEPTACLE. Cigarette Lighter. Electric. Floor Console. Seat Separator for 2006 Chevrolet HHR. #25774623
Here is the one that shows as the one in the dash. RECEPTACLE. Cigarette. Cigarette Lighter for 2006 Chevrolet HHR. #25776667
Are they interchangeable? I sure don't know.
Old Jan 22, 2017 | 07:52 PM
Randy. Guess it would depend on which one you had in front. There were 2 options. A regular power outlet(not sure if it's the same as the rear console outlet). Or the cigarette lighter outlet that came with the Smokers Package option.
Old Jan 22, 2017 | 08:45 PM
the power outlets come with a cover, If you put a lighter in it things will melt. and there is no retainer spring in them.
My 2008 and 2011 LTs had outlets front and rear.
Old Jan 22, 2017 | 09:11 PM
The plastic pieces seem to be separate parts, using the same socket.
Here is the actual lighter insert and ashtray. Cigarette Lighter. LIGHTER. HEATER. Cigarette for 2006 Chevrolet HHR. #11516140
