No Power to right side fog light?
Old Feb 4, 2017 | 03:21 PM
oldracer's Avatar
I check the board now and then and have not had to do very much to my 2007 HHR 2.4L model as it has been about the most reliable car I have owned in several years. Except for some brake pads, normal oil/filter changes I have had to do nothing to it. About 3 years ago I installed replacement head light housings with HID lights already installed and they have been trouble free as had the HID fog light bulbs I put in the same time. Several nights ago I noticed the fog lights seemed a bit dim so I pulled into a parking spot so the lights could shine on the glass and the right (passenger side) fog light was out.
So today I jacked it up, removed the wheel and popped the liner and installed a new bulb assembly. I bought a new set for both sides since when one goes out the other usually follows soon after. Hummmm, no right side light, left is fine? So I pulled the connector and there was no power at the right side plug connector. There is only one fuse for both so I am wondering what it could be. I am leaning towards a bad ground but have no idea where it might be?
Anyone have any ideas?
Old Feb 4, 2017 | 03:53 PM
Same as you, check the ground wire connections
Old Feb 4, 2017 | 04:14 PM
oldracer's Avatar
Well wherever the ground from the fog lamp plug goes, there was an opening so no ground. I had to pull apart the plug on the lamp side and run a new ground wire to a screw on the inner fender that I added. I wrapped the connectors well with tape so hopefully they will be waterproof.
Old Feb 4, 2017 | 06:02 PM
Good , so the light is working?
Old Feb 6, 2017 | 01:13 PM
oldracer's Avatar
Yes both lights work now. I imagine that there is a break in the ground wire somewhere that cannot be seen or easily found. This happened to a Ford my daughter had but it was the power wire to the left side lights. So in that case I ran a tee off the right side power supply and all was okay? On the Ford forums this seemed to be a well known issue and most people did the same thing I did.
Old Feb 6, 2017 | 05:11 PM
The ground is in the harness from the right side to the left then up to the left side engine compartment.
Kane2727
Mods - Exterior
Apr 2, 2012 10:46 AM
da_dad66
2.2L Performance Tech
0
Apr 8, 2008 08:03 PM
itschaboykenny
Feb 17, 2008 12:01 AM
